1979 Aquasport Family Fisherman
Dennischaves
I found the perfect candidate for my next restoration. It’s an Aquasport family fisherman 176 I believe it’s the same hull as the osprey
The boat has a very nice ride
The stringers are foam filled and the deck is built like a tub inside the boat
Does anyone have any suggestions on removing the cap I know there’s foam everywhere below the deck so I’m assuming removing the cap will be a challenge
If your boat uses stringer tubs, most likely the cap was glued to the hull and stringers with plexus before the foam was injected
