1979 inline 6 water coming out around the plugs
GOTFIVE
inline 6 115 merc 1979 water is coming out around most of the plugs what gasket is that called thanks anthony
Clams Canino
Re: 1979 inline 6 water coming out around the plugs
That's the water jacket gasket AKA cylinder block cover. If you can, try to seal it as best as you can from the outside. Removing that cover can be *trouble*. And if you break a bolt, you'll likely have to pull the powerhead to repair it.<br /><br />-W
GOTFIVE
how would you seal it from the outside there are about 3 that are leaking already tried to remove bolts broke the first 2 sprayed them with pb blaster . whould you seal it with a sealant or epoxy thanks anthony NY
Gotfive, Use silicone caulk. It is a bit messy, but the alternative is to break the cover bolts, drill them out, retap and install a new gasket. Also, on my 1977 inline six, most of the broken cover bolts could be drilled through the block and square 1/4 - 20 nuts would fit on the backside of the block.
GOTFIVE
thanks guys for all your help hopefully one day i can repay it thanks anthony NY
