1980 regal marine 240 midcab 260/8
snyderm140
I was given this boat and need alot of help! I was told it was ran about a year ago but husband doesn't think so. It has 2 batterys 2 switches 2 engines, the lines coming from the switches are 2 red from each switch and looks like a black from each motor can some one tell me were these should go? we did figured out 1 battery is bad.We tryed hooking all red from one switch to + and the black to - nothing. Is this some thing we should put money into? they are mercruiser 3.0. the only paper work we found said it was insured in 1989. any info on this boat,motors, any thing would be great.
Haut Medoc
Re: 1980 regal marine 240 midcab 260/8
Welcome to iboats.....:)
Try hooking up the red & black wires directly to a battery that is known to be good on each engine individually.....
One at a time & see what happens.....
While the batteries can be hooked up in tandem, i would address each engine individully at first......;)
Without Pictures,+ Much More Info,.......
That's Pretty much an Unanswerable Question.......
