1981 Merc 260 Stalls shifting from fwd to reverse
ronjon444
My 1981 Merc 260 is stalling when I shift from Nuetral to Reverse, it shifts and runs fine from Neutral to Forward. It has gotten progressiveley worse through the end of the season. Any suggestions?
Haut Medoc
Re: 1981 Merc 260 Stalls shifting from fwd to reverse
Your lower shift cable is on its way out.....
Replace it......;)
Ayuh,.......
That's Classic symptoms of a Junk Lower Shift Cable........
Replacement is the Only Cure........
