- Joined
- Jul 23, 2011
- Messages
- 52,522
FYI - hydro-mechanical drives were white, full mechanical were silver
your drive color will determine the drive you have.
Better as a two man job. I can lift it by myself, but without a cradle to easily set it on (which I built) it's a real strain. If you build a stand for the drive, and have a way rock it on and off - one guy can do it easily.Also is the drive heavy? Like a 2 man job or just 1 big guy?
Yup. Merged 'em over here for engine/drive stuff. If you start workin' on hull stuff, just start a new topic over the restoration forum where you had the other topic goin'. :thumb:I have been asked to combine this post with another one that I started a few days ago. Can you do this?
I was about to type that I think that's the part number of the gear case ... but now I feel like I monkeyed that up somewhere before. It might reference the gear ratio of the upper. Either way: it's not really the model number of the stern drive. OMC didn't really work that way.Model of sterndrive is 983159.
Mechanical shift would be the best.Looks like it's a mechanical. Is that good?
