1982 starcraft v220 mariner v5 potential rebuild
Crabeye
Hi all..have had this boat for a while now..looking to take off floor and redo it..transom seems very solid..it's an outboard..never been messed with...I've got an issue where some of the rivet heads on bottom fall off when tapped...not too many but enough to give me concern..would this be scary situation when hitting waves etc. And rivets start failing?.what would be best advice from you experienced starcraft guys..looking to put a 140 suzuki 4 stroke on it as well...use of boat would be west coast ocean..(bodega bay area) and sf bay halibut..next question is would this boat be able to handle the salt (corrosion) ..not planning to leave in berth..it hasn't been painted on bottom or bottom paint..thanks JC
Crabeye
Adding to post now...I guess my fear is that is it actually possible for seams to pop open? Also..does anyone have input on what flotation my 1982 starcraft should have..and could I do a very effective flotation add on..after I do rivets and gluvit?
MNhunter1
She's a big girl! I'm envious! Galvanized dual axle trailer too!
My assumption is after removing the deck you will find yourself with some saturated spray in foam. I'd yank it all out, give it a good cleaning, and assess all the rivets. You may find corrosion/pitting inside the hull where the saturated foam has sat against the hull, especially if it was a salt water boat. Rivet heads shouldn't just pop off with ease. If they do, I'd methodically go through and hammer in all new solids with a healthy dose of 3m5200, pending the hull assessment and your time investment deems it to be a worthwhile effort. It'll be some work, but will be a wise investment if you are planning on holding onto it for awhile and your intended big water/ocean use. I'd take a hard look at the transom as well and do it as a piece of mind, even though it may seem to be solid at the moment.
If you're lucky, you'll find the foam board flotation under the deck. Not sure when they moved to the pour in on the Mariners/MR, or what the standard was for the V5 hulls, but my 1984 18ft had the pour in foam. Wish it didn't, but it did.
Excited to follow along with this one!
Crabeye
Might be a 1983 as well. I couldn't find a 220V in the '82 catalog, but they had one in the '83: https://starcraftmarine.com/sites/default/files/catalogs/StarCraftAluminumRunabouts1983_web.pdf
I just went off the registration..stating 82...but trolling this site I understand this boat can handle pretty big waters..sure has a ton of fishing room to drift fish halibut,lings,and rockfish..am I to also understand it a little beefier as far as ribs,etc.? Has 240 max. Hp rating
Gibbles
Gibbles...tell me more please..pm me if you wish..I'd like to be fully informed of what I have here..
The better hull!
More reinforcements, tale tale is the long rib on the outside.
I think those earlier ones also had the lattice structure inside of the hull.
My islander is an example of the much later version of the hull design where it became the "V"
Example 221V would be the reinforced hull design, earlier woukd have 221 V5
On my 94 it's on the id plate by the driver position, but they also moved the reinforcements inside of the hull, so all you see is the pattern of the rivets.
On yours, it's clearly presented on the outside.
I have another post where i put in a comparison, someone is just looking for information on what to buy.
Watermann
Welcome aboard, the V5 designation was the early model of the Vs to come in the 80s and Starcraft was proud of them making emblems and decals to show it off. Another give away is the port side fuel filler.
Gibbles
Might have been late 70's as well.
One i picked upbfor dozer years ago was a 78 or 79.
If i recall it had V5 decals, but that was a very long time ago.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Welcome @Crabeye !! Im just east of you in the sierras and Im familiar with the waters out on our coast. Havent taken my boat out there yet as its a bit smaller than yours, but Ive surfed all over and kayak fish for rockfish and lingcod.
Similar to your issues, I had rivets just losing their heads when I first got my boat. Once I almost sank when a rivet lost the head and tail, slowly filling up my boat while fishing... ended up replacing almost 200 (10%) but the PO had hit a log which cause a lot of damage to my boats structure.
In your case I wouldnt be caught dead on the north coast ocean waters without tearing the boat down to a bare hull. As someone else said, check every rivet below waterline with a hammer on the head. It will fall off if its compromised. Fix all the bad rivets with hard solid rivets and 5200 sealant. Check and fix corrosion if any. Then coat-it or gluvit all seams inside. Replace flotation foam with closed cell foam board from the big box stores.
For the bottom, Id personally go bare aluminum if you're going to be primarily in salt water. Add a good anode to help with corrosion. Always rinse your boat well. Replace any dissimilar cheap metal with SS and aluminum. A few big bilge pumps is a really good idea too.
Looks like a great project! Id love a V5 hull and keep my eye out for them. Pretty rare to see them come up for sale, especially in the nice condition yours is in. Once you get it all rebuilt and repowered with a 140, it should handle a lot of the days out there on the big blue.
Crabeye
Well!! Finally I've made some progress and have decided to go all in! lol..I've pulled floor,removed all foam..soon to pressure wash..looks pretty good over all..checked all rivet heads on bottom that had heads flaking off...hit them ALL pretty firmly..Will have to redo like 50 !!! I need to buy some..I think most were the ones between hull and carpeted bunks...will probably do gluvit then i guess will do the leak testing before foaming..any support ,Emotional and mechanical is welcome..im virgin aluminum rivet boat guy...have a nice 140 suzuki 4 stroke for it..thinking near shore westcoast boat for me..I like good weather and swell!! I'll get some more photos figured out soon
MNhunter1
Wish mine was a 22ft'r...but then it wouldn't fit in my garage. I'm on the home stretch of wrapping up my MR180. Just need to finish up the wiring and mount the motor. Looking forward to following along with your build! Happy to help wherever I can.
garbageguy
Looking forward to your photos. Emotional support here (and these days I like to see photos of OTHER PEOPLE's work), looks like you've been getting mechanical support from the other good folks here
Crabeye
Crabeye
It had pour in foam...but that is all removed..it is actually pretty clean inside..I haven't pressure washed yet! Pretty soon..want it really clean..Again comlete rivet check and replacement then gluvit i suppose..I am questioning on a really good way to put flotation foam back in...is there a reason I should put pour in foam back(structural?).im leaning to an alternative to that..Who has a good recommendation? Also as a good flooring plan such as what material ?
cyclops222
That hull can spread apart as you remove interior structures to get at the floor. You may not notice it spreading slowly as structures are removed.
isn't that mostly on glass boats? The aluminum has ribs attached not like a glass where one is removing the stringers.
cyclops222
Not sure about his size. I would measure near the widest part of the hull now.
Then keep measuring as structures are removed.
The glass boats are floppy sometimes.
