1983 Mercruiser 120 outdrive oil filter
madmans
What car type filter do you guys use on this engine? Also where would I buy a fuel sghut off switch for a inline shut off thats reliable? And do you run 30 weight oil in these engines or will a good 15-40 delo 4000 supreme be OK??? Thanx Mike
Re: 1983 Mercruiser 120 outdrive oil filter
Mike you should repost this in the I/O section. I do not think that motor is rated for ordinary auto multivis oil. SAE 30 and Quicksilver 25W-40 are probably approved for use.
