1983 Mercury 50 HP 4 cylinder Electric Start Wiring Diagram
Status
Not open for further replies.
warrencross720
Re: 1983 Mercury 50 HP 4 cylinder Electric Start Wiring Diagram
is this wiring also same for 78 model or is it different?
displaced47
here is diagram and info from my manual for 1982 merc 50 hp https://picasaweb.google.com/bj.michielsen/Wiring?feat=directlink......hope this may help you guys out!!!
This is brilliant!!! Thanks heaps - do you also have the wiring diagram for the tilt/trim pump for the same engine? I have a 1983 50hp too and the tilt trim was all pulled apart by the previous owner. I'd be grateful if you could help!
cheers and thanks
denwoodjones
Anyone have any guidance on what happens on the other side of that connector? I just got an old 45-50 (595XXXX SN), and it has no ignition switch... just wires. Trying to make heads or tails out of which is which, what needs power to run, and which one I short to trip over the starter, which one (if any of these) is the choke control, etc.
cyclops222
Buy a Factory Manual with the color codes of the wires ?
How else can you possibly avoid destroying things ?
I would want the wiring diagram.
Here is likely wiring diagram in color.
If your wire colors match, then red is +12VDC; black is ground; blk/yellow is ign killer; yellow/black is choke solenoid; purple is power from ign switch; grey is tach signal; yellow/red is starter solenoid;
An ign switch will normally have terminals marked B, M, M, C, I, and S. Red goes to B; black goes to M; black/yellow to the other M; yellow/black to C; yellow/red to S and purple goes to I. The grey wire is routed directly to the tach signal connection.
Remember the ign is powered by the coils under the flywheel. It does not need any battery power to function, and battery power to the ign system can cause serious damage,
Status
