1984 3.5hp lower unit oil seal replacement
Schnidly
Dear Forum, can someone give me direction to remove the cover nut for the propeller shaft on my lower unit? My serial number is 6298133 if someone wants to take a look the parts diagram to see what I am talking about. It has 4 slots around the edge where to put a cover nut tool, but finding this tool seems to be impossible. Is there a chance I can use a flat ended punch to tap on the indents on this ring to remove it? I need to replace the oil seal on the propeller shaft and thus have to remove the prop shaft and bearing carrier to get to it. Please advise. Maybe somebody has a homemade tool they made or Im just missing something here? Thanks so much
I recently did the same for a 1969 7.5 hp and the tool for that is 91-99222T. However the 3.5 hp might be different. I would not recommend trying to remove the cover nut with just a punch tool (or similar) on the indents, as the cover nut is very soft and easily deforms. I tried doing that and ended up breaking the cover nut. Had to buy a new one.
Maybe check the oldmercs . com site to see if the tool is the same or if they reference another one.
It took me a while to find the P/N for the tool . . . does not seem to be well published.
Schnidly
OK, I did figure another method for taking the cover nut off of the lower unit. I have a small long nosed vise grip which I adjusted to the diameter of the indents on the cover nut. I then used an adjustable wrench on a flat spot on the vise grip as the tip of the vise grip was seated in the indents on the cover nut. This worked pretty good. I had soaked the cover nut threads in penetrating oil for a couple days prior to attempting this without a spanner wrench. It worked like a charm. Hope this helps someone out sometime.
