1984 BAYLINER VOLVO PENTA AQ125A
giniustflord
I TROTLE MY ENGINE IT GOING GOOD PICKING UP TO SPEED AND PROPER RPMS THEN IT SLOWS DOWN SLIGTLY I LOOS NEEDED RPMS DONT KNOW WHATS DOING THIS<br />I THINK MAYBE MAIN JEST HAS FLOTING DEBRE PARTIALY BLOCKING IT CARBS BEEN RESENTLY REBUILT NO LEAKS <br />ENGINE OVEHALED NO PROBLEMS <br />I SET THE TIMING BUT THE DISTRIBUTOR SET BOLT IS ALL THE WAY TO ONE END<br />IF I JUMP ONE TOTH ON DISTRIBUTOR THEN ITS ALL THE WAY TO THE OTHER SIDE<br />THINK THE TIMING BELT IS A TOOTH OFF FROM WERE ITS INTENDED TO BE<br />HOEVER I CHEAKED IT AND BOTH MARKS ARE DEAD NUTS WERE THER SAPOSED TO BE<br />AND HARD TO PUT THERE I MIGHT ADD AS BELT TENDED TO TRY AND SET IT HALF A TOOTH OFF<br />IT HAS NEW POINTS AND CONDENSER AND NEW COIL AND YES INTERNAL RESISTERED<br />I HAVE VERIATY OF PROPS 15-15 15-13 15-17<br />I WAS DOING 48 TO 49 HUN DREAD RPMS THEN SLOWED TO 4000 ON IT OWN<br />ANY IDIEAS
Re: 1984 BAYLINER VOLVO PENTA AQ125A
ANY IDIEAS
1) Welcome to the Boards............... :) <br />2) You have a Fuel related Issue.....<br />Your motor is running out of Gas, at High RPMs......<br />3) Invest in a Spell Checker....... :D
giniustflord
LOL THANKS BONDO AND YOUR RIGHT MY SPELLING SUKS BIG ONES LOL AND I DONT REALY HAVE THE PATIENCE TO USE A SPELL CHEAKER <br />OW AND I SELDOM IF EVER USE GRAMER<br />SORRY GUYS<br />BUT HEY ABOUT THE RUNING OUT OF GAS THING<br />WHAT DO YOU THINK THE CAUSE COULD BE NOT ENOUGH FUEL IN CARB BOWL OR INJECTER CLOGING OR LINES TO NAROW?ANY IDEAS<br />THE BOWL NOT HOLDING ENOUGH COULD BE IT I DID MESS WHITH THE FLOT STOP AT ONE TIME<br />BUT I DID HAVE A GASKET WITH RTV SILECON ON IT AT ONE TIME AND DID FIND SILOCON CLOGING JET<br />AT ONE TIME<br />CAN A CARB BOWL EMPTY FASTER THEN CAN BE FILLED<br />MY FUEL PUMPS NEW AND ITS A MARINE VOLVO PUMP
giniustflord
thought id bring this post back up to the top jest to get atention :]
JoeW
Ginius,<br />Check your fuel line for small cracks. I've had the same problem and it turned out to be a hairline crack in the fuel line that ran for about 6". It was hard to notice. <br /><br />On another note, in addition to checking your spelling, you might want to set your keyboard to lower case as some see all caps as shouting. <br /><br /> :rolleyes: <br />-Joe
