1984 Marner V6 150hp No Spark
82skeeterm
Please Help, I tried firing up my 1984 Mariner 150 hp V-6, and I had no luck. Compression and feul are there but there are no sparks in the top two cylinder and bottom two cylinders. The middle two cylinders has sparks. How do I go about fixing the problems? How do I know if the coils and trigger are good. Could it be a faulty switch broad? Any suggestions will be much appreciated. Thanks in Advance...
Re: 1984 Marner V6 150hp No Spark
There are troubleshooting guides on the web. You have an ADI Ignition, and Dolphin Marine Services has an online manual.
Laddies
Banned
Here is the test from CDI
