1985 305 Exhaust Manifolds Fit on 1981 305 heads?
J jmw129 Petty Officer 1st Class Joined Jun 12, 2011 Messages 253 May 20, 2012 #1 1985 305 Exhaust Manifolds Fit on 1981 305 heads?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,442 May 21, 2012 #2 Re: 1985 305 Exhaust Manifolds Fit on 1981 305 heads? Ayuh,.... SBC exhaust ports haven't changed since 1955....
J jmw129 Petty Officer 1st Class Joined Jun 12, 2011 Messages 253 May 21, 2012 #3 Re: 1985 305 Exhaust Manifolds Fit on 1981 305 heads? Bond-o said: Ayuh,.... SBC exhaust ports haven't changed since 1955.... Click to expand... So I don't have to actually swapt the heads then, just the exhaust manifold itself?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,442 May 21, 2012 #4 Re: 1985 305 Exhaust Manifolds Fit on 1981 305 heads? jmw129 said: So I don't have to actually swapt the heads then, just the exhaust manifold itself? Click to expand... Ayuh,.... Depends on the pick of the litter, after a thorough inspection of the candidates....
J jmw129 Petty Officer 1st Class Joined Jun 12, 2011 Messages 253 May 21, 2012 #5 Re: 1985 305 Exhaust Manifolds Fit on 1981 305 heads? Bond-o said: Ayuh,.... Depends on the pick of the litter, after a thorough inspection of the candidates.... Click to expand... Very good point! If I have a better head to bolt on in addition to better manifold then it makes sense to swapt them both.
