1985 baja sport 200 small cracks ????
jjzepplin
I just bought a 85 Baja and found that a brace under the dash was broken. It bounced around too much when under way so I got up under there and noticed the break.I have since repaired the problem but now I have small cracks in the dash that need tending to and a place where the previous owner cut a hole in the dash for a radio. How do I fix these problems? The radio hole was for an old style with the two knobs and is too small of an area to cut out a larger hole for the new style rectangle type. I would assume both of these problems have the same fix? But then you know what they say about that word ***-u-me !!
Re: 1985 baja sport 200 small cracks ????
Ayuh,.... I'd think MarineTex might work...
