Need too find out how too take the prop shaft out of the housing too replace the gear Joe
J joe agey Seaman Apprentice Joined Oct 11, 2011 Messages 34 Mar 23, 2014 #1 Need too find out how too take the prop shaft out of the housing too replace the gear Joe
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,640 Mar 23, 2014 #2 Re: 1985 evinrude 150 lower unit Which gear do you need to replace?----There are 4 screws inside the propshaft bearing carrier.------Then you pull that carrier out.----Then you need a big pair of snap ring pliers to remove 2 rings.-Then reverse gear falls out.
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Mar 23, 2014 #3 Re: 1985 evinrude 150 lower unit A good factory service manual would really help you. They sell them right here on I-Boats.
J joe agey Seaman Apprentice Joined Oct 11, 2011 Messages 34 Mar 23, 2014 #4 Re: 1985 evinrude 150 lower unit both the forward and reverse. I took the boat out on a scout trip and the lower unit went out. joe
E emdsapmgr Supreme Mariner Joined Dec 9, 2005 Messages 11,551 Mar 23, 2014 #5 Re: 1985 evinrude 150 lower unit Agree, work from a factory manual. The reverse gear is sold separately, the pinion and forward gear are sold as a matched set.
