1985 force 125 wont turn over
my outboard will not turn over and she has a brand new battery im jus wondering what can i do to test the problem so i can repair it on my own
jerryjerry05
Re: 1985 force 125 wont turn over
Remove the plugs and try to turn it over.If it turns over do a compression test.Will it trurn over by hand?
Then pull the drain plug and check for metal shavings in the oil.
More info on what you can and can't do.J
JB
What, exactly, does not turning over mean? What happens instead?
