1986 115 2 stroke rebuild
1986bassbuggy$@
I have a mercury 115 that has blew a hole in the intake manifold beside the middle carb, now im no expert but this doesn't sond like a broken rod being inside the head and not the block, does anyone have an idea of what couldhave done this?
I would like to try and rebuild this motor but need to start with the culprit.
Thanks
Faztbullet
Re: 1986 115 2 stroke rebuild
It threw a rod...start looking for a block.
1986bassbuggy$@
whould any other inline six blocks work other than the 86 merc 115 i found a mariner 115 isn't that made be mercury?
Faztbullet
Any Mariner/Mercury from 1980 and up will work,you will just have to do a mod on the fuel pump on the older block as they dont bolt to block.
The hole could have been caused by the exit of the connecting rod cap and bearings. The block is still toast.
