Hello................ As stated above I have a 25 HP Mariner. Its been running GREAT for two years now. I use almost every weekend in the summer only. Last weekend while running jugs it had a very small miss I detected while idling. So I figured I would change my plugs as they were old and possibly clean up the miss. I changed the old plugs with new one, went to the local landing to put out some crawfish traps and it did not start. I ripped a hole in my skin trying to start it............... I pulled the plugs and found out that they were not firing. An interesting event was that at the end of each pull cycle of the started rope the spark plug would give out one spark (on the last revolution on the crank shaft)????????????? I can also hear a little click as this on spark happens. So I got home and put in old plugs and the same happens. One spark at the end of the cycle. One other interesting fact is that the one spark I can get it to inconsistently produce does not spark on every pull, but I do hear that click coming from somewhere.
I just tried it again this morning. No spark from plugs but I did get a shock as that click sound happened while holding the plug wires. Also with both plugs just hanging from the plug wires I pulled the rope and noticed one spark from the side of the lower plug to the latch that secures the hood as the click sound is heard also. The spark is about 1.25 inches long.
ANY HELP WILL BE GREATLY APPRECIATED!!!!!!
It may be a 1995 model I am thinking if that help trouble shoot the problem.........................
