1986 35hp carb
hadaveha
I just picked up this really clean motor for a little skiff, I removed the carb to clean it good and I noticed. Something seemed to be missing. I?m assuming theirs a brass plug that is supposed to go in the bottom of the bowl here. Well I?ll have to work on getting the pics smaller. It?s at the front side of the bottom of the vertical float boat
OK, looks like a sidebowl carb. If so, there is a brass plug on the left part of the carb under the carb bowl and bowl cover. Under the throat is a blind bolt hole for a choke or enrichener.
Best I can do w/o a picture.
