- Joined
- Oct 25, 2011
- Messages
- 25,274
Re: 1986 Ebbtide Dynatrak 150 Restoration
You are towards the bottom of the temp window for the resin to kick, so I don't think an hour is unusually long. If you have any halogen lamps, you can set them up opposite the area you are working on, under the hull or just to the outside of the transom, and as soon as you get the layup where/how you want it & your tools/work area detailed, turn the lamps on to gently warm the hull.
Might only save you 30min+/-, but 2 or 3 half hour time savers would greatly increase your production over a period of several work sessions. Even just 1 extra layup per session would be helpful.
