1986 Four Winns front Hand Rail
Re: 1986 Four Winns front Hand Rail
They have the tubing here on this site, but what do I do about the curve?
Ayuh,.... Bend the New to match the Old...
greenerob
Right, if I had the old ones, that would be easy. Is that how this type of things is done, or do they make prebent tubes?
What does "Ayuh" mean. I see that you say that everytime.
SeanMcl
I helped a friend bend some rail tubes for a missing rail. We took some spare 12 gauge electrical wire, the kind you use in house wiring, bent it to match the curve of the boat, and then used that as a guide when we bent the rail. He had a roller type tube bender and it turned out really good.
