1986 Mercury 50hp 3-cyl - Shift Shaft Disconnect
rcwannab
I recently acquired a project boat with what I believe to be 1986 Mercury 50hp S/N: A 952458 (pic attached)
I have not had success yet finding the factory service manual for this particular engine.
I plan to drop the lower unit and replace the impeller, but didn't readily see how/where to disconnect the shift shaft.
Any hints or advice where to disconnect would be much appreciated.
Thank you in advance.
I think the shift shaft is splined and just slides out.-----No need to disconnect anything.
