1987 Bayliner Trophy Hartop 4 Blade PROPS.. I dont know what buy
longstand
I currently have 3 Blade Prop "13-1/4 X 17"
AND I WANT TO HAVE 4 BLADE
I will usually have two kids, 4 Adults. with Full tank of gasoline, Foods and drinks.
what is the BEST 4 blade props should i purchase.
I have seen this prop for sale.
Solas Amita Aluminum Boat Propeller #2413-128-17 for OMC - Outboard Marine Sterndrive Model 400, 3.0L Thru 1989 140 HP - iboats
I'm not worry about going MAX SPEED on this boat. Its just to cruise. I have read that 4 props blade will be best for use of my boat. but that's from other forum.. I dont ONLY trust input from Iboats.. :rolleyes:
Please Advice. and if your kind enougth. have a link from iboats store of which i should purchase
Re: 1987 Bayliner Trophy Hartop 4 Blade PROPS.. I dont know what buy
Ayuh,... There ain't no answers, til ya offer This information,...
jestor68
Here's some general guidance.
RPM range should be 4200-4600. You'd want it turning near 4500-4600 rpm for good overall performance.
If you want to maintain about the same WOT rpm, drop to the next lower pitch ( 15 ) when switching to a 4 blade prop.
If you put the same pitch 4 blade on there, expect to drop 100-200 WOT rpm.
So the decision as to what pitch you need depends on what WOT rpm you're getting with the 3 blade 17.
steelespike
We need all this information to not only evaluate your performance but also to tell if your tach seems to be accurate.
They often are not, especially those that have some years on them.
Also speed by gps is the most accurate as speedometers are also known to be suspect.
longstand
WOW.. I never knew All of this affects of what kind of prop i will need to purchase..
I will not be able to take the boat out next month. due to work. and maintenance of my out-drive.
I Perform the WOP test with a GPS on my phone and provide all the SPECS necessary for the best answer to my question from you Nice peoples
Starcraft5834
"I currently have 3 Blade Prop "13-1/4 X 17"" nice boat (pic)...heavy with deep V-hull. 13.25 dia seems a bit small to me.. you need to know your numbers,, WOT/RPM.... I'd venture a guess about 16p 15 dia 4 blade prop would push you nicely.. if you have anode fin, you might consider removing it and putting on a flat anode.. when I took off my 3 blade in favor of the correct 4 blade, made a huge difference, also installing a flat anode (I had to, as the 4 blade was larger dia) steering at slow speed with 4 blade and flat anode became much smoother.......
longstand
15 x 16p. 4 blade prop. now i need to find one. hahaha..
Starcraft5834
right here on iboats...use prop locator,, there's plenty of em.......get your #'s first,,,,you will find the right one
longstand
That iboat Prop locator is Great!!.. and Iboats has good price on them props.. I wish i could afford the stainless prop instead of the aluminum.
steelespike
Don't get a prop until you get us your performance numbers.
Your diameter seems undersized at 13 1/4" X 17. 17" props for 3.0 are 14 4/5 diameter to about 15"
Does your present prop seem to have issues?
Starcraft5834
get your performance # fist Long.....you will be happy with Aluminum.. what you have been offered thus far are guesses.....
longstand
for sure. i will not purchase the prop yet until i perform the WOT test. The reason i want to purchase a Prop is just i want a 4 blade prop and my current prop little damage on the edge..
also. i have notice that there is a gap between the prop and the buttom of the stern drive. the size of the tip of my finger. now sure if i could purchase a bigger prop.
This boat is not for speed. i just want to be able to optimize my RPM and fuel. i will usually just use this boat for cruising around san diego bay
Starcraft5834
gap? not sure what you mean.. do you have an anode with fin or flat?
longstand
Here is a picture. Can i purchase a bigger prop?
jestor68
Your OMC 400 drive can take up to a 14" diameter prop.
You won't see that large of diameter unless you drop down to the lower pitches.
longstand
like a 4 Blade 14" 16 P?
Going to WOT test this boat. but i have no RPM Gauge.. hAHAHAH.. a trip to autozone i GO
Starcraft5834
thanks for Pics. get your tac...# you might not need a larger dia blade going to 4 blades....
jestor68
If you go to the prop section and look up props for your OMC 400 drive; you'll see that a 4 blade blade is usually a slightly smaller diameter than the same pitch 3 blade prop.
There is a reason for this. It's called blade area.
Whether you'll need a 17 pitch or a 15 pitch 4 blade depends upon what WOT rpm you're turning now with the 17 pitch 3 blade.
longstand
I will take out the boat out this Sunday. and I will test the WOT. and Then i will provide the information.. YAY. i can't wait
