1987 Omc Cobra 5.7 Outdrive Question
87 bayliner
Im Getting Ready To Reinstall The Outdrive And Need To Know When Reinstalling The Out Drive What Position Should The Shift Lever On The Outdrive Be In? Neutral ? How About The Shifter Itself ?
Also, Is Permetex Required On The Gasket Seperating The Outdrive From The Transom Assembely ? What About Lubricating The Shift Cable ? Any Insight Or Advice Is Welcome
Thx In Advance
J
HT32BSX115
Re: 1987 Omc Cobra 5.7 Outdrive Question
Howdy,
There is a LOT to reinstalling the drive according to the manual.
It talks about doing the " Shift System Neutral adjustment" prior to installation.
There's some VERY critical measurements to do this correctly.
There's info HERE about this also.
If you attempt this without a service manual you may end up damaging the drive.
You need an OMC #507605 manual.
Regards,
Rick
It needs to be in neutral.
