1988 Alpha I won't go into reverse
pmgrape
I have a 1988 renken with a Mercruised 3.0L and Alpha I outdrive. I've been having trouble getting it to shift into reverse. I had the lower unit apart to replact the pump and was able to shift the lower unit into reverse and forward with no problems. I also removed the upper unit and cleared out all the nastiness in the space around the end of the lower shift cable. I also removed the lower shift cable from the engine and with the engine running I mannually pulled the cable. It moved good, and netral and forward were no problem, but I couldn't hit reverse. <br />Could my lower shift cable be in need of replacement? Could there be some play in the linkage between the end of the cable at the transome and the lower unit?<br /><br />Thanks<br />Brian
crazy charlie
Re: 1988 Alpha I won't go into reverse
Originally posted by pmgrape:<br /> I have a 1988 renken with a Mercruised 3.0L and Alpha I outdrive. <br />Could my lower shift cable be in need of replacement?<br /><br />Thanks<br />Brian
Thats a very good possibility if it has never been changed before
Haut Medoc
Yes! I would replace the cable.....JK<br />You could try adjusting at the "Barrel Nut", but I would just replace the 18 year old cable & I would check the condition of the u-joint bellows as well ;)
Did it have Reverse Before you did the waterpump,..???...<br />Did you do the service with EVERYTHING in Forward,..??....<br />
Your Issue COULD be Either,... Or Both.......
pmgrape
The cable appears to be the original cable. It was starting to not want to go into reverse last year before before I replaced the lower unit pump.<br />I'm thinking it could be the cable too, but I'm just wondering if there could be an issue in the upper unit between the cable end and the lower unit that could cause this.<br />Thanks
