I just picked up a 1988 Tracker 17 Magna with a 70 Merc. The rig has been stored for years, used to belong to a good friend and has perhaps 30 hours total on her. I noticed a small area of the deck just aft of the rise for the bow platform is a bit spongy, thinking it could be a joint there or some dry rot since it has been kept inside for so long. Given that this boat is like new I may want to remove the floor and fix the spot at some point in the future.
I realize that these boats are not high end and it's fairly obvious as I clean and check out components such as storage compartments, wiring and plumbing.
Appears as though it can be done without too much trouble over the winter. I attached a picture of the inside of the engine to show how clean it is, more to come. I'm in the process of replacing the oil and fuel lines as they are dry rotted. She pumps strong but am also going to replace the water impeller. I drained the fuel tank and was quite surprised that the gas was in pretty good shape after nine years. I'm mixing it with fresh and using it in my mowers.
