1988 Force 88 hp, help on wiring cdi
KD5EXP
I got an 88 Force 85 hp years ago on a trade. 1 power pack out on it. All the wires are loose and hanging. I need help with figuring out where the all go. It's a wiring night mare. Wiring diagram helps a little bit need more help. The CDI modules are 116-3301 and both are the same color wires. Someone please help me before I loose my mind.
Thanks in advance
Gene
kd5exp@hotmail.com
Nordin
Send me a PM and I will send you back the wire diagram as a pdf file.
jerryjerry05
DON'T get crazy!! It really isn't that bad.
Is the diagram still on the side of the exhaust chest?
Before I'd do ANYTHING!! I'd do a compression test.
