1988 Johnson 70hp inspection
Prop guy says block must be at a certain temp to bore correctly.
Any details you have would be muchly appreciated.
Matt
I never heard that, and mine turned out ok. Remember, your inky removing a tiny amount of the dia....015 up to .030. Heavy cuts might make a difference.
Bored a couple of cylinder jugs on a lathe w/4 jaw chuck, but no engine blocks.
A block would take forever to set up properly on that Bridgeport. Much better off using a mill designed specifically for engine work.
Very true, but sometimes you use what you have. I worked in a die shop at that time, we had all kinds I of setup fixtures...at home in a garage....yep would be a challenge !
Yeah, he said he thought they had to go into a freezer. Obviously they shrink and expand based apon temp. If anyone knows if that's true please speak up.
Right now I have two 30 hp and a 70 jphnsons that have low compression in some of the cylinders...usually here in Seattle its off to the scrap yard.
If you have access to the mill practice on a junk block and see how things go.
I guess you have nothing to lose. That’s the kinda of project that would be on the top of my list just to have fun and see how it came out.
When I was a kid I got TH350 transmission from the junk yard and rebuilt just to see if I could.
I didn’t have any parts left over so I think it would have been fine but never did try out. 😂
Basically that's why I'd be doing it to, just to see if I can! Doing it in Seattle will mean that I'm going to lose money, oh well! 😆🤣😆
Btw, I have the TH400!
Faztbullet
You have the bridged port exhaust and these engines are prone when water pumps get weak the bridge expands and scuffs the exhaust side of piston, You will find when you tear it down piston may have a a small oil hole for bridge. The replacement pistons will not. I drill them in piston to oil bridge and relief the bridge with a Dremel about .001. Never had one comeback. As for boring at certain temp room temp is best 70-80° as motor doesnt expand much at 120-150°
All great info, thank you.
