1988 Merc 115hp dies once put in gear
69olds442
I am new to the world of outboards. I recently purchased a boat with a 1988 Mercury 115hp 6cyl OB. The week prior to this problem I am about to describe, I made the mistake of running a tank (10 gallons) of 50:1 gas mixed half with 2 cycle chainsaw oil, and half 2 cycle outboard oil. I've since learned that was a mistake, and wont do that again. While using that gas, the motor ran semi-rough at low rpm. The entire tank was used under 1000rpm. I had no problem putting it in gear, and running at the low rpm, and it staying running.
I just filled the tank using Quicksilver plus, 2 cycle marine oil mixed 50:1, no-ethanol 89 octane gas. Took the boat out and now as soon as I put the motor in forward or reverse, it will stall out. I do seem to hear a low and high idle once the engine is started. Sometimes it takes a few seconds for the high idle to kick in, like something might be sticking. If I quickly put the motor in gear and advance the accelerator to just the right spot, the motor will not quit. If I give it a little too much, it will bog down and die. If I make it past this problem, the motor runs just fine, and purrs like a kitten at high rpm. Ideas?? thanks.
Dave1027
Re: 1988 Merc 115hp dies once put in gear
Maybe the spark plugs got fouled?
Dallenx
I tried these two products and they worked great.
QuickSilver Quickare
QuickSilver Quickleen
Also, a small hole in the fuel pump diaphragm will do that to the engine at low idle then the problem seems to go away at high speed.
You could test the fuel pump pressure visually and with a gauge.
mr 88
Was it accelerating okay before your fuel issue or is this your first time out ? If first time I would try adjusting your 3 slow speed idle jets. One at a time and starting with the top I would open the jet 1/8 of a turn then test.Then move down to the middle ,turn out 1/8 then the bottom carb.If it works okay after one adjustment,stop if not continue on.Doubt it is the fuel pump as you state it runs great when you drive through your issue .
69olds442
spark plugs are a zero-gap type plug. I suppose I will still clean them.
69olds442
generally speaking, it was accelerating fine before this tank.
I've had the boat for about 6 weeks now. The first tank of gas was 100% chainsaw oil mixed 50:1. (I wont do that again) We were out tubing. Toward the end of that day, they symptom started to show up. We emptied the tank that day.
My next fill up I mixed 50% chainsaw oil, and 50% marine oil, no-ethanol gas, 50:1, 87 octane. Used that entire tank trolling over 4 days. No problem engaging and running at idol. Never exceeded 1000rpm on that tank.
Third tank I used the correct oil. Quicksilver plus, 50:1, no-ethanol gas, 89 octane. This is when the problem became consistent.
I am unsure at this point if the problem may be related to using a 2-cycle air cooled oil. I don't know if that my have messed something up, or if something else is going on.
Sounds like dirty or mis-adjusted carbs. Mercs are widely known to stall when put in gear. Maybe some junk got stirred up in the fuel tank and found it's way to the carbs?
BTW- Don't sweat the chainsaw oil. Don't use it again, but don't blame it for anything.
69olds442
just spent some time working on the motor.
Cleaned the spark plugs. they looked good to begin with.
did a compression check. anywhere from 115-120lbs on all 6. that's good.
did a spark test at the same time. oops! no spark on #1 & #5. #3 is very weak.
will focus my efforts there...
69olds442
reversed the stator leads going to the switchboxes. The problem of no spark traveled to the odd cylinders. Ordered a new stator today
BatDaddy1887
Use a half-a-can of Seafoam in your next tank of gas. I use half-a-can every few tankfuls and it keeps it clean as a whistle. Amazing stuff.
