1988 Sea Nymph GLS - 17'
  • Center Console
    Votes: 7 38.9%
  • Side (or Side by Side) console
    Votes: 11 61.1%
  • Total voters
    18
  • Poll closed .
GT1000000
Re: 1988 Sea Nymph GLS - 17'
Soooooo, someone gets a surprise visit, isn't home and doesn't get any elf-work done...
BTW, nice job on laying out and cutting the front deck...
TruckDrivingFool
Making some good progress!
Good thinking on extending the deck to the consoles.
Decker83
Stopping by to wish you and your family a Happy Thanksgiving Day from the Admiral and me.:)
jbcurt00
From the Admiral & I to you & yours:
May you have a great weekend & enjoy the company of friends & family....
John
Trooper82
Happy T Day PMC...and family....and the boat is looking good!
Pmccraney
Thanks Fellas -
Troop, you probably saw the scribble on the my bow deck when you stopped by today... I cut a few hatches in the last bit of daylight we had...
Trooper82
I did see the marks, and was curious what you were up to....lockers and a livewell? Looks sweet man!
sphelps
Wow the layout looks great ! Your gunna have one sweet fishin machine pmc !
Have a great Thanksgiving ! SP.
Pmccraney
Trimmed up the bow deck this a.m. (a little pre turkey work session). Fits the console nice and flush- I like it.
jbcurt00
Looks great! Nice job fitting the deck to the console & nailing the notch layout
jasoutside
Man, she is certainly coming together!
Have you kinda set a target date to have her floating yet?
Just wondering eh.
Hey, I like pumpkin pie, just thought I'd tell you that.:D
glnbnz
Looking good PMC and I hope you had a great Thanksgiving :)
TruckDrivingFool
Just wondering eh. :D
It's kinda fun when it's not you getting that question isn't it? :)
Really nice job fitting that deck PMC, hope you and yours had a great Thanksgiving.
Pmccraney
Just wondering eh.
I like pumpkin pie too. :D... and stuffed my pie hole with it yesterday.... Splash date... Hmmm... In the back of my mind I am shooting for March 1.. Could do some spring time fishing down in Louisiana, and then hit the early spawn for bass... But, I still have a few spendy items to acquire to make that happen (tilt and trim, gauges, electrical stuff, new water pump, etc...). . At least I don't have to buy a windshield though... :) I was able to get the boat all the way in the garage so with a mild winter and space heater I maybe able to make some progress... We'll see.
I did.. It was great.. Hope you and the rest of the iboats gang did as well.
Thanks TDF - appreciate the compliment. Hope you had a good turkey day as well.
Here is a little black friday update (thank goodness I'm not into shopping)...
First, I cut and insalled the underside pieces for the hatch supports... A nice slathering of PL Glue like clown make up, and some SS screws with 5200... Then, I fabbed up those little brackets for some extra support....
Then a little trimming and sanding... fit like a glove - I was pleased:
Then, tucked her in for the night with a little epoxy on the underside with a little heat lamp...
Hope everyone is having a great holiday weekend.
~PMC
sphelps
Great job pmc , your rounded corners on the openings are perfect . The deck to hull cut looks dead on !
Whats going on up at the front of the bow ? Will that just be decked in or maybe more storage ?
Pmccraney
Good question. It's going to be decked in. Not quite enough room up there for another hatch. I'm waiting to do it though because the bow light, dock lights and trolling Motor install will be a lot easier without that piece blocking my access up there...
Trooper82
What did you use to get that deck so snug? same template system we used for stringer to hull? Also...how high is the transition from main deck to the bow deck?
I'm ready to put one in mine today...and want it to go as good as your's has...
I'm considering using a string and pencil as a compass, figure the sides of the bow are a true radius...we'll see I guess...
Pmccraney
Its 16 inches vertical height... I wanted that front casting deck pretty high... I may build a little step up between the consoles or just park a small cooler in between the consoles...
On the shaping:
It was really easy for me, because the gunwale radius and the hull radius are just about exactly the same...and I had an open bow.
So, I measured my port to starboard length at three places (where my cross hatches were).
X____ X (e.g. 30 inches)
X_______X (e.g. 55 inches)
X__________ X (e.g. 67 inches)
(the above was supposed to look like christmas tree - not flush to the left; the formatting won't work).
Then I threw the board on top of the boat upside down and made sure it was perfectly square to front cross hatch and that my 3 "X" marks on the starboard side were resting right on the starboard gunwale edge... Then I just got a sharpie and traced the edge of the gunwale right through the 3 X marks. Shifted the board over a bit; got the board square again; made sure the port side "X" marks were all right on the edge of the port gunwale and traced again....
It took about 10 minutes... Way easier than I thought... Jas has some pictures of this method on his Sea Nymph thread as well. I stole the idea from him.
Trooper82
ok, that makes sense..more or less the same way I did my deck...
