1988 Thunder Craft 162 Regancy restoration
Status
Not open for further replies.
model14
Just completed the restoration of the subject boat. I paid $750 with trailer and have invested about $1500 more. She runs and looks great IMHO.
Before pictures:
Thunder Craft 014.jpgThunder Craft 016.jpgThunder Craft 017.jpgThunder Craft 019.jpgThunder Craft 020.jpg
model14
Re: 1988 Thunder Craft 162 Regancy restoration
More pictures:
Thunder Craft 7 003.jpgThunder Craft 7 006.jpgThunder Craft 8 007.jpgThunder Craft 8 025.jpgThunder Craft 10 018.jpg
model14
And still more:
Thunder Craft 1 006.jpgThunder Craft 2 001.jpgThunder Craft 2 006.jpgThunder Craft 5 004.jpgThunder Craft 9 010.jpg
model14
New parts included:
Battery, starter, fuel pump, carb rebuild kit, outdrive water pump, tachometer, slave solenoid, shift cable, fuse holders, switches.
I had to make a significant repair to port and starboard box stiffeners.
model14
She has the 2.5L 120 HP engine and Mercruiser outdrive. Does 25 mph at 3000 RPM and 30 mph at 3600. I have not had it any faster. A comparable boat of 16 feet with a 90 HP new is about 14 thousand with trailer. I am proud of her!
Thunder Craft 9 003.jpgThunder Craft 5 008.jpgThunderCraft 6 7002.jpgThunder Craft 10 017.jpgThunder Craft 10 033.jpg
Very nice! Good Job.
dded
I bought the same boat as yours! By the way great job!!!! I have a couple of questions, 1 the floor on mine is worst than yours, did you replace plywood an fiberglass over top? Seats you used are they reg are did you have to build up off floor? Outter she'll what did you do to make it shine? My gas tank had to be pulled, found leak was in gas line! Thanks for reply! I was in VF-11 on board USS Forrestal 1968-1971!
GA_Boater
Old thread and OP has been gone for a while. Start a new thread.
Closed.
Status
