1989 90 Hp Johnson Block Question Pic Attached
Clyde Jones
sorry I'm not trying to hijack your thread. I do like the fact we have similar motors :D
trelos67
Appreciate the help Clyde, good to see someone else trying so save one of these old girls Cheers
The ring on the head gasket seals against the iron cylinder sleeve. as long as the sleeve is intact, and the sealing surface is smooth, the gasket should seal.
emdsapmgr
new head sample.jpg 130 lbs is strong compression for an engine with the low-compression "bathtub" heads.
trelos67
Well D day has come, just had a call from the shop and the boat is ready for collection. Question with out notice, the mechanis told me they cleaned the damaged area up and filled it with a product called ITW Devcon. Have any of you guys heard of this stuff? Awaiting a call back to tell me how much this little episode has cost me.
Faztbullet
Devcon is best stuff on market, used in aircraft and such. I use it all the time,not cheap but the best.
