1989 90 hp mercury trim motor
RandyJ
I'm tired of searching. Never had to deal with one like this. I don't see one in catalogs or online that is identical. Somebody help me out. Apparently this trim motor is toast. Which one do I need? Serial number OD190210, 3 cylinder.
Sites like crowley marine should have the part number for the OEM replacement. You can then search for a Sierra, ARCO or other replacement.
QBhoy
Hi
i got a replacement for my old 90 a while back. It came from a force engine. Same thing if it helps.
RandyJ
Thanks guys. I finally broke down and called DB electrical. They had a cheap one that works fine. Oddly, I found the same one cheaper on another site after they got my money...
Texasmark
"Stuff" happens. I learned that after I buy something, I quit looking as usually what happened to you happened to me. Wink!
