Lou C
- Joined
- Nov 10, 2002
- Messages
- 13,973
Re: 1989 Bayliner OMC 3.0l..replace or???
Don't know if the specs for an 88 and 89 are the same, but my 1988 OMC shop manual gives 4 BTDC for 89 octane gas, and 1 BTDC for 86, Point gap is 0.019, dwell 31 to 34 degrees. Idle is 500-600 rpm in gear.<br />If you have an antisiphon valve, make sure it is in good shape, it can restrict gas flow and cause performance problems, I had that a couple of years ago with my 4.3
