1989 evinrude 3hp impeller?
jstme
Just got this motor today and was planning on replacing the impeller before i used it as I dont have a history on the motor. While looking for the impeller in the iboats store i didnt see 1 listed, only 3hp evinrude they list is up to 1978. Is this motor water cooled or air cooled? If it does need a impeller any tips on this perticular motor? Any other things I should go over before i put it in use?
Vic.S
Re: 1989 evinrude 3hp impeller?
Yes it is water cooled.
pump in usual place SEE HERE and PARTS LIST
Ditch old fuel make fresh with TCW3 spec oil.
Check gearcase oil for signs of water ingress (while you are doing the pump is good time to do the seals if necessary) and change or top up again.
Some useful suggestions if not been run for a while or simply new to you at http://forums.iboats.com/showthread.php?t=158086
