1989 Force 125, main jets are different size
Cyclone
Top carb has a .094, bottom has .1015. Is this normal, or should I even them out? If so, where can I buy one? Thanks.
gm280
I have no experience about you particular engine. However, you could go on to any Force engine parts site and look up your particular engine and see what the part numbers are for the two carb jets. That would verify if they are different or not. Or even talk to most any marine service shop and ask them. I'm sure they would know as well...
Nordin
I do not know if you mixed up when you wrote the thread. But the bottom carb shall have 0,0937 main jet from sea level up to 1500 foot and the top one 0,101 from sea level up to 1500 foot.
Cyclone
Thx Nordin, you're right, I did mix up the info. Looks like I'm good to go.
