1989 Johnson 150 GT aftermarket fuel pump replacement???
Rderrick121
Hello everyone, I am seeking a replacement fuel pump for my 1989 Johnson 150 GT J150STLCE. I do not plan on using the oil injection as it has previously been eliminated. Looking for the cheapest solution.
Also If anybody has any information on rebuilding/cleaning the carbs for this motor I can't seem to find much on this exact carb.
Any help is greatly appreciated, thanks!
What is the motor doing / not doing ?-------Have you done a compression test ?----------Carburetors are simple and straight forward.------Not much can go wrong with them !
Rderrick121
Motor won't run unless I squeeze the primer ball when its past idle up around 2k+ rpm. It also won't idle but its been sitting for awhile (at least 2 years) I am thinking the idle jets are blocked and the carb needs cleaned. Piston head compression is good just checked the other night, the pulse on fuel pump doesn't hold pressure.
Thanks, Richie
