1989 Volvo Penta AQ271c cooling system
jhetrick55
Hey, I'm looking for some advice on part of the cooling system on this engine. Where the raw water hose comes through the transom, it goes into a plastic fitting which turns into a black tube with a couple rubber hoses coming off of it and at the top it goes into the raw water hose which runs to the impeller. Sorry I don't have pictures.
Does anyone know what this black, vertical tube does? Is it possible that this tube could be plugged? I can't seem to find anything to help me identify this. Thanks!
Power steering cooler, and it's copper
If you are having cooling issues, check the fitting on the drive
jhetrick55
Scott, I have replaced that fitting with a brand new one. The old one crumbled when I removed it.
As for the power steering cooler, if I flush water out backwards, it doesn't seem to have any issues - comes on good and strong. QBhoy... you're suggesting it may have trouble due to corrosion internally? What is their lifespan generally?
if you are concerned about the power steering cooler, pull it out and have it pressure tested.
they are a simple pile of plumbing tubing and parts.
QBhoy
Yeah. They can suffer and end up causing a loss of prime to the pump.
kenny nunez
Another place to check is the seal where the lower gear housing contacts the water tube on the suspension fork. When the boat planes off air enters the incoming water flow.
Sierra #18-3888 lower seal kit.
Raise the drive and drain the oil and with some Allen wrenches the lower drops off. This is an easy job.
