1990 120ho force king pin question
gica
Does anybody know off hand what it takes to get to the king pin and bushings?
I bought the really cheap from Marine Engine I mean 32 buck shipped fo4 bushings and to king pins. That's free they are 60 bucks USD în Ebay.
I have the motor off and the drive off how hard is it to take out the old king pin that is all dinged out and bushings and install new ones?
Does the leg have to come off?
Thanks guys.
you should have a manual.
I believe the power head comes off
jerryjerry05
Not an easy job.
To make it easier, the head and lower unit needs to come off.
If it's ever been in salt water?? 10X harder.
Need a factory manual too.
An acetylene torch helps.
Take pics and post the procedures when done.
gica
Not an easy job.
I have the motor and and lower drive off. Does the pin slide out now or do I have to remove the drive shaft housing, cover leg etc. There is a soft plug on top of that pin. I have not seen it sold seperstely so I don't wanna break it.
Looks like your all over this motor 🙂, you should have a manual , honestly a PDF of the manual will be the best value for money you could spend fixing up this motor 🙂.
I assume the king pin is the steering pivot shaft and bushes.
I replaced mine , got a 500mm bit of stainless tube off aliexpress and made a new one .😁
gica
I have the manual thanks I looked it up there seems to be a washer and a cap on top to remove and then you hammer it down with a punch. I found the exact replacement original from Marine Engine and the plastic bearings. I think the pin is stainless. It was so cheap like 12 bucks plus 4 dollars for the bearing
36 for 2 sets. I could not refuse. I cannot wait to get it done. I wish I would have done the second motor when I was rebuilding it.
They have the original crankshaft with the upper bearing on for 215. That's unheard of. I 5hink it's gonna turn out great.
I am going tuna fishing right after hahaha.
I got a bit lucky ,the original shaft was 1 inch and the aliexpress shaft was 26mm so I turned a bit of dia off the end so it would press into the yoke....and happily the extra .6mm was how much the original bushes had worn so the whole thing fitted together pretty good .
gica
Not an easy job.
As you said it won't budge.
I have a torches but it is a Map yellow
It is stuck inside. This is supposed to rotate in the bracket right?And the bearings inside are plastic.
gica
It finally came out I hammered a medium size 1/2 inch extention on the top of the king pin heated the bracket up with the map for 5 min hammered it really hard from the bottom first until it came out half inch on top. O think the heating did the trick. Bottom bearing came out haf way I am still trying to take out the top one using 1/2 inch 5/8 socket and extention from the bottom. OK it's out. Alotof crud where the plastics were.
So the motor is supposed to spin in the bracket bearings right? Mine was spinning on the front motor leg cover so on the external part of the king pin. I had to loosen the 8 bolts on the cap cover for it to spin easily. The king pin was not moving at all.
How would you clean that salt build up?
The plastics probably gradually got wrapped around the king pin tighter and tighter from that.
gica
Ok I cleaned the bracket king pin hole.
The plastic bearing sleeves go in really easy now
I have no clue of that is normal and how they function. Never put new ones in.
Maybe Jerry can tell us I am sure he did it before.
Also half way down the hole there is another sleeve that won't come out is that there permenent. I think it's a stopper for the plastic bearings.
Am I supposed to just put the new sleeves in with so.e king of grease, sealant etc and the king pin too?
gica
Not an easy job.
Hey Jerry when I get the plastic sleeve bearings and king pin do they go back easily or they have to be hammered in ?
Do I need grease in there? How do I prevent near future shaft build up?
Let me k n ow thanks
jerryjerry05
Always needs grease, LOTS!!!!! of grease. Never too much grease.
I don't think they need hammered in.
Usually I can get enough grease in to loosen the kingpin.
Sometimes it needs an acetylene torch to loosen the old sludge/grease.
Just don't heat at the very top or very bottom. Some bushings are plastic and can melt in place and lock the pin and it will never move.
Did I mention more grease?? and MORE grease??
MORE GREASE and heat can loosen the pin.
Some cases the sludge or old grease/sludge can lock it and when adding more grease the zerk can pop out. Then tapping a new hole in needed.
The future: GREASE and more GREASE!!!!!
I GET MY MESSAGE ACROSS???? more GREASE!!! :)
Yeah ,heaps of grease . I work on the theory that if its full of grease then no water can get in .....works for wheel bearings too.
I also use crc soft seal on some parts ....like the bottom clamp on that steering shaft. I spray everything with soft seal ,assemble and wipe off the excess.
My original pivot tube was steel and while the outside of the tube in encased in grease the inside was rusting big time .....enough to foul the gear shift rod .
gica
Yeah I have to remove the second engine also.
I will look at Softseal. I like FluidFilm too. It protects pretty good. I will spray both and put grease. By the way whay grease do you use.
They were both frozen in place. The motors were turning on the outside pivot of the king pin. I hope now I can have an easier time turning the twins.
I noticed the pin is a pipe opened on the inside.
Should I seal the top and bottom so water doesn't get in there? You mentioned yours was rusting on the inside. If there is a lot of grease on the outside of the shaft maybe sealing the middle would prevent water intrusion.
Just a thought.
Just a thought.
The soft seal is a waxy that sets about as hard as soap.
The grease I used was Timken bearing grease....but only because thats what was in the gun . There is marine grease available and I spose thats the best but I think as long as you pack something in there you ok .
The outside of my pivot was rusty and the bushes had stuck to it so the bushes were rotating with the shaft. I looked at plugging the end of the shaft but the gear select rod goes down the inside of it so I just sprayed the soft seal in from bothe ends .
jerryjerry05
Marine grease is the only grease to use.
IF?? you ever go in salt water?? Marine grease should be used.
Fresh water you can use regular grease but why risk seizure again??
gica
I got the parts for the replacement king pin put it in and now the pin has some play inside. Everything new the king ping from Marine Engine for #25 engine so 19 inch long.
It slides in real easy and it falls out if I don't hold it. When the engine will be on it will have ever so slight play.
I don't have a new set up to compare and the other motor is stuck e8th the same issue so I have to
Is that normal?
I haven't filled it with grease yet
Cut yourself a slice of soda can the length of the outside circumference and the hight of the bush and and pack it in behind the bush .....if that dont work put 2 in it🙂
