1990 5.0 omc quits when put into reverse
southkogs
Welcome grooter:
I don't know much about the Cobras, but what might help the other guys help you: does it stutter and die like it's overloaded or choking? Or does it slam to a stop?
swaycleveland
only in reverse? Im thinking the shift interrupter switch is out of alignment.
grooter
It stutters bobbles and dies out.... I have adjusted the idle and it seems to have fixed the problem...'idle is at 900-1000. Is this proper
swaycleveland
nope idle is about 600 to 800 rpm id check the timing also. the timing would make it stutter, lower the idle and make it prone to dying out.
You can easily get the ESA out of the equation. Just unplug it and see if it still stalls going into reverse. You may have to turn the engine off to get it out of gear though so do this test where you are away from other boats and docks.
