1990 90hp force not oil injected?
manitoba
the motor im looking at is not oil injected(gas/oil mix).
why is not oil injected and is that good or bad?
Also is that a chrysler or merc motor?
Are these soft motors?
thanks
Re: 1990 90hp force not oil injected?
It is not oil injected, you must mix the oil.
Why? to keep the price of the motor down.
Is not a Chrysler.
May be a US Marine motor, but is likely a Mercury.
1990 is the year Mercury bought Force from US Marine.
Don't know what a "soft" motor is.
manitoba
Sorry by "soft" I mean does it break easily or is common for breaking down.
jerryjerry05
Your motor was made by Force (formerly Chrysler)a section of US Marine.They were sold to Mercury and for a few years Merc put their touch on them:electronics and a few other touches.Then stopped making them.
They are a good motor if taken care of.A little more expensive to run.
I have had a pair of them for 20 years and they still run good. 1988-85hp
on a 21CC. Jerry
On your motor, the ignition system was problematic.
Mercury replaced it with their ignition in late 1991.
The 90 hp was a decent motor.
Most failures occurred from lack of maintenance, failure to replace the water pump impeller on a regular basis, and failure to mix the oil into the gas.
GrindKore
thanks
Oil injection in 2 stroke motors is overrated in my opinion, it just adds extra complexity and more possibility for something to go wrong. Premixing gas with 2 stroke oil takes less than a minute, I would never trust oil injector more than myself. The 1990 Force 90 is a good motor if you take care of it. This motor is relatively simple, which is a good thing if you are in to DIY maintenance.
Bigprairie1
Roscoe what was the problematic part of the ignition? Is this in the Blue prestolite ignitions?
BP
