1990 Force 50 Prop Questions
Hello All! <br />I have a spun prop and started doing research on them. I love knowing my options! This is a 1990 16'7" Bayliner with a 1990 Force 50 motor. This motor has the Pin Style Prop on it. I do plan on having the Hub rebuild on my old prop, but Im shopping for a second primary prop and will carry my old as a spare. HERES THE QUESTION: Do they make a SS prop for this motor? Ive been shopping and cant seem to find anything other than aluminum? Does anyone know the "Standard" pitch. I see on Iboats there are about 4 choices ranging from 10-14.5 degrees. I DO know about checking the RPM vs. Speed to select the correct prop, but unfortunately my prop spun before I could do the calculations. New boat to me!
JB
Re: 1990 Force 50 Prop Questions
Moving to Prop Forum
Doubt that a SS prop is available.<br /><br />There is no "standard" pitch.<br /><br />What prop is on there now?<br />Post all the numbers on the prop, and hopefully someone will be able to tell you what you have.
