1990 Galaxy 225 Weekender fuel tank location
Fisnfool
I just picked up the Galaxy. I know I need to change fuel lines to ethanol compliant if it has the old lines in it. They may have been changed, there is a modern 1 quart water separator filter on it. Does anyone know the locations of the fuel tank? It does have the fuel filler on port side of the swim platform area. Have not traced the fuel line back to the tank yet. Back strain. I want to be looking in the right area when I get to it. Don't know if it is behind the access panel on the stern where the battery is, or under the deck. The guy I got it from only had it 2 months . He showed me phone videos of it out on Lake Erie past few weekends.
He only had it the short time because a friend in PA transferred it to him so he could use it until he sold it for him.
Does anyone know the fuel tank capacity.
Usually the fuel tank is just forward of the engine bay. Open up some hatches and have a look.
Fisnfool
Thank you sir. I was able to get into the boat today. no hatches to completely view tank. But I could see the tank end with the doghouse removed. It has a poly tank. I'll have to change the water separator. It is the old style with a plastic bowl. I have a complete new assembly I can install. I am going to run 90 octane fuel from the fuel dock in it.. And add the enzyme fuel additive. Ethanol is not an issue with marine fuel.
