1991 120hp Force stalls alot
Hockmed
The motors runs great but i'm not sure what adjustment i need to make to help from stalling at idle, its annoying trying to dock and keep stalling out. just wanted to see before i stuck my hands in it. lol
fyi, new plugs and new upper and lower unit last year. good compression and spark on all cyl.
thanks for any help
jerryjerry05
Re: 1991 120hp Force stalls alot
The set screw at the bottom undo then turn it in.It needs to be running and warm.Attach a tach make sure the rpm is around 750-800.
The tack on board is not always right.J
Hockmed
thanks ill try that if it ever stops raining, lol how would i hook up the tach?
jerryjerry05
Just like on a car.My multi-has one built in.It also cost $600.J
