1991 4.3 exhaust cooling holes size?
Bumperlt12
I meed to add nipples to the risers to accommodate the thermostat housing. I can find the part though.
Is the port on the exhaust manifold the same size at the one on the riser?
I need #12 from picture. Seems its unavailable but that the parts listed at #7 will work, if size is correct.
Can someone chime in?? I'd really like to get more things ordered!
That should work but I would go with these to make winterization easier
Merc 22-862210A01
Sierra 18-4224
Could even go to local hardware store an find a straight or 90
