1991 454 ignition problems?
Spyder208
I'll appologize if this post gets long, 1991 OMC King Cobra 454 with a distributor less ignition, I bought this boat in January, it has been in storage since 1997, 173 hours, test drive in January boat ran ok, had old gas in it and a very dirty Holley 4 bbl, it flooded and ran very rich. I've done all the oil and filter changes, swapped out the Holley for a new Edelbrock Marine 750 cfm, water pump impellor, new bellows and gimbal, 170 psi compresson on all 8 cyl, now to the problem, boat has run fine in the yard, launched in the water yesterday and taxied out slow, opened up throttle and it pops and sputters badly, back off the throttle and it clears up, give it gas into the secondaries and it back fires and runs horrible again, I ran around the lake for 10 min and it cleared up for about 10 seconds felt like it had a turbo on it then back to the popping and sputtering, does this sound like timing advance issues? any thoughts appreciated. Can I do away with the OMC electronics and put an electronic distributor on this motor? It also pops and sputters in neutral, back at the dock it seems like it cleared up, I can free rev in neutral fine, but it got too dark for a test drive.
Re: 1991 454 ignition problems?
That Sounds like it's Still a Fuel Issue.........
JohnDawkins
I have a Merc 454 7.4 Bravo 1 which is constantly throwing the belt off the power steering. Any suugestions?
Spyder208
Bondo, does it sound like a lean issue, Edelbrock is new out of the box with no adjustments, or does it sound like dirty fuel? It has a full fresh tank and a new spin on fuel filter.
Spyder208
Bondo is the winner!! It was fuel related, took a new fuel filter and some Heet to the lake tonight, changed the filter, poured some Heet into the carb and the rest into the tank, boat runs like a rocket ship, 60 mph, no problem, thank you!
Originally posted by Spyder208:<br /> Bondo is the winner!! It was fuel related, took a new fuel filter and some Heet to the lake tonight, changed the filter, poured some Heet into the carb and the rest into the tank, boat runs like a rocket ship, 60 mph, no problem, thank you!
:D ;) :cool: <br /><br /><br />JohnDawkins,...... Start Your Own thread,+ Help will come to you,.....Hy-Jacking this thread will get you Little or No Help......
