1991 Force 120 tilt/trim issue
cinder1995
Over the last three years i've had to take the trim motor apart and clean the brushes and the armiture and it will work fine. This last time it didn't do the trick. I checked the brushes with my ohm meter. It had continuity. The armiture spins freely when in the pump, so it's not binding up. Is it possible that the armiture has gone bad. If so where is a good place to get replacment parts or even a new motor. <br />Thanks
Re: 1991 Force 120 tilt/trim issue
Online Armature - Distributor of Marine Products<br />850 Barefoot Williams Rd.<br />NAples FL 34113<br /><br />email onlinearmature@comcast.com<br /><br />239 775-7161
