1991 Force 150hp- no spark, #5 cylinder??
gregr1971
I have a 1991 , 150hp, lost spark on #5, i have replaced the stator, due to it "sparking" while running , under the flywheel, stator had a burnt spot where the brown/blue wire comes off the stator, also replaced the cdi box for #4 & #5 cylinders, and the coil for #5.
now i am stumped??????
Re: 1991 Force 150hp- no spark, #5 cylinder??
Is the trigger sending a signal to fire the cd ?
JJB
I had a few problems with the power pack droping cyl on my 91 150 . Do you have the thunderbolt system ? If so they tell me that you should replace both the power pack and the dc voltage box that feeds the pack together
gregr1971
no thunderbolt, it has the other system with the 3 blue powerpacks, and 9 milion wires.
ok, got the new timer base, not the problem, now it fires intermitently on 3 & 5, after it warms up. ???????????
1,2,4 are fine.
