1991 MerCruiser 3.0 Alpha One
devon84
Re: 1991 MerCruiser 3.0 Alpha One
Oh ok no there is no oil leaking what you where seeing was waterlogged milky grease from the bellows leaking and filling with water.
devon84
Also I pressure tested the outdrive and it was good at 15psi for 30 minutes.
Bt Doctur
ok then ,but it sure looked like oil.
devon84
Bt Doctor thank you for all your help I'm extremely grateful. I hope you will continue to help me as I conquer this project.
devon84
Alright now I've got into the fun stuff. The perch that the front motor mount is supposed to be bolted to is rotted out so I've got to build a new one, waterproof it with resin then fiberglass it in. I don't have any good pictures of what I'm talking about but here's some of the where the was and then after I got it pulled out.
You can kind of see the front mount dropped down in this picture the rotten wood collapsed out from underneath it
After I got it out
And a couple of the completely destroyed coupler
