1992 Alpha I Gen II Outdrive- Engine Stalls in Neutral
victoryinerie
I replaced the bellows and shift cable last year, and I went to go out this year and the boat starts with no issues when I am in Nuetral Forward however when I pull the throttle back into nuetral the boat stalls out. Any suggestions what needs adjusted??
Help...
Bt Doctur
Re: 1992 Alpha I Gen II Outdrive- Engine Stalls in Neutral
improperly routed cable,damaged cable. too high an idle speed
victoryinerie
Do you mean the shift cable or the throttle cable....
