1993 15 hp Johnson Stalling
also...see Leroy's on part 25 & 27 possible blockage in part 25
also ..reread your post #1... dealer adjusted the carb.... "the carb looked fine"
but was the carb ever taken apart for a full soak and clean-up of all passages...then adjusted
93Johnson
Hey - thanks for that. I agree with what you’ve written and plan on doing just that to the carb. I couldn’t get it to run for very long yesterday so I have winterized it (it rains every day here) and will work on it again in the spring. Right now I’m thinking it’s a fuel problem as well so I am going to install a new fuel line as 8 think there must be something wrong with the line or the valves in the squeeze ball. Thanks again.
totally amazing at $140 hour.... imagine if he reallly worked on it .
report back in Spring it would be nice to know if you got it purring
